Changing Rear Springs
Andy74tii
support rear of car on jack stands
place jack under control arm and lift 1"
disconnect bottom of shock - lower jack
SLOWLY! and the speing might come out.
you may need to disconnect the anti-sway bar,
and you may need to remove the securing C-V joint
screws at the hub so the arm will lower more -
all depends on what spring is in there now
which dictates your path weedhopper.
you may also need a spring compressor
if they are the original tall springs
stay kool
stay kool
Do what C.D said.
  • 3 years later...
Definitely.  Isn't the shock what limits downward travel?
I am pretty sure you can carefully lower the arm using a floor jack, once those three thins are disconnected.
I just dug up some old photos, from when I did mine.  It looks like I used a scissor jack.
You can see that the spring does not have far to go, before being fully unloaded.
010.thumb.JPG.687a41197cb6f640de636b3451e44362.JPG014.thumb.JPG.7f92d60950af9b742efa2df3932e4b80.JPG017.thumb.JPG.bb9cd5d60403a3c0ec6d3800b830c87c.JPG
For a stock spring, you'll have to either undo the CV or use a spring compressor of some sort.  There's not a lotta room
for the normal type of compressor, but those ty-wraps scare me.  So I unbolt the CV.
And yes, the shock mount has to be unhooked at the bottom.
Use a small jack under the trailing arm, as the spring has significant preload on it.
Most aftermarket 'lowering' springs do not.
fwiw
2nd, 3rd, 5th whatever the use of a spring compressor.
Fatherof3... that zip tie method is downright negligent. So sketchy and dangerous. Car springs hold a LOT of potential energy.
When I did my H&R's it took compressors to do both the removal of stocks, and installation of new ones.
