Downpipe Question
Anschauer
Hello everone.
on an otherwise stock '76 (center exhaust) am replacing the Ansa with a new Ansa system and went out and purchased from (Stuart here in Brewster) a Borsal downpipe when we found the old one had been welded up by the PO.
You can see in the picture that the angle is off by several degrees and also the length is about 2 inches short
of making a proper connection (disregard some of the length issues here as that was PO welding.
The Ansa intermediate pipe has no up angle to mate with the downpipe, therefore the down pipe has to terminate horizontal (ie parallel with the underbody)
Any thoughts or ideas welcome.
post-36155-0-11321900-1373730558_thumb.j
