Timing Tii Issue
billjecks
Ok finally found the ball on the flywheel after the eraser trick. It is my impression that at idle the timing mark
on the pulley should line up and then at 2400rpm you should see  the ball on the flywheel,indicating full advance. I cannot bring my timing pulley back far enough to line the marks up at idle without stalling and the ball is showing at a 1200 rpm idle. ?????????. I am thinking maybe a broken spring in the advance plate???
any thoughts??
Bill
vancouver bc
1973 tii
