Thermostat
davetolen
I live in Nogales, AZ where we've been at, or over, 100º for the better part of the last three weeks, and our elevation is 4,000 feet.   But, year round, I run a 71ºC in both my ' 75 automatic and in my wife's '76 automatic and they may run a little on the cool side when the morning temps are in the 70-80º range, but never overheat on the freeway, even when it's hot and we're running around 80 mph.
Bob Napier
Edited by Napes
thermostat temp is not related to the climate you drive in.  t-stat temp regulates the internal engine operating temp.  it should be kept at the optimal temp for engine operation.
the ability to remove heat from the coolant is related to the climate you are in.  the radiator and fan are what controls this, NOT the t-stat.
use the t-stat designed for your car and make sure the efficiency of the cooling system is up to snuff for the climate you are in.
I checked a copule online parts suppliers showing 71, 75 & 80C. Is there 85C thermostat?
Thermostat opening operation in Haynes manual showing 80C. And of course coolant system current condition could have impact on your selction.
Curious which thermostat I should purchase. I've seen three different types : 71, 75, and 85 degrees. I own a 72 2002. I do live in Santa Fe nm where it gets pretty hot in the summer.
Thanks
Dave
Been tellin folks that for years but they seem to want to cure an overheating problem with a colder set thermostat!!
