Positive/ Negative Effects Of Spring Pad Removal
Dabliz02
On the front, I would not remove the rubber cups at the top of the springs.   Mine were trashed so I cut them off.  From that point on, with every turn, my springs (under pressure) would rotate/spin and a loud snap/pop would ensue.  Apparently metal on metal is not part of that original design.
Don't know about the pads.
REAR:
remove top rear 3-Dot - 3 different thickness upper pads and
lower the car and  increase NEGATIVE CAMBER
leave bottom rubber for noise insulation
and prevent rusting between spring and control arm
FRONT:
leave the thin top and bottom rubbers for noise and rust
insulation - nothing to gain at front by removing front
rubbers
Edited by c.d.iesel
REAR:
FRONT:
rubbers
so the rear doesn't require a top pad at all? thats a good half inch drop... for free... nice!
yeah there is no connection , my thought was bigger wheels/ tires, and then was thinking that my car sits a little too high.  Then came a thought about removing/ playing with the pads (thinking along the same lines as Rocan) as an alternative for a slight drop.  But I will probably either cut the spring or go full coilovers.  But probably c/o in the long run.
