Glass Is ..........making Me Wet
New windshield  going in (dark green shading too boot !!  As i pass this glass to a so called pro, is there any thing i can over see (know it all :angry: Franky
 I got the Crome bead ,and the gasket.
ps the leaking  on my left foot has got to come to an end!! :ph34r: ... that said my blinker relay is so soaked wet with this issue......and is..... also pissed.
I want to know what precausions i may take or (know it all :angry: Franky) may take, in order to support the dry cabin.
PS i have the 73, that also leaks  on my left :blink: foot.
Sun roofs yes .
post-38154-0-18108900-1370529372_thumb.j
Thanks . Look the lower corners were showing some leak just after they put in the shield.
Again what can I put in that gasket inside as well as out to prevent this leak permemantly .
Sil glide is a paste of some sort that is designed for ?...... Or do I silicon ? Thanks
Sil glide is a silicone lubricant that is a paste and it repels water. I'm not a fan of sealant on windshields cause they dont need it. Just pull the gasket back a bit and push some sil glide in on both sides with a paint brush or something. Repeat as necessary, I've only had to do it twice in the first couple months then it worked fine. Best of luck!
