Potential Tii Efi Conversion Parts
Mike_B
I came across a couple items that I thought were interesting.  It looks like these MFI to EFI injector bungs in combination a fuel log in the place of the Bosch pump plumbed with some hard lines to injector caps would allow for an EFI conversion of a Tii while keeping stock appearances.
I wonder if there would be adequate clearance under the intake plenum for the bungs, injectors and caps???
http://classicautowerks.com/mfi-injector-adapters
http://foxinjection.com/index.html
7511035_orig.jpg650;650;8aaea737b9abf8df4771d8ce457b1b87
People have done just that with early 320i intakes- they look like tii manifolds, but are almost free in junkyards.
The 6- cylinder crowd's using them to sneak EFI into E9's and such...
I was pretty impressed with the injector caps.  The challenge with the 320i manifold has always been fitting the fuel rail under the plenum and fabbing up mounting points.  The caps should make the process much easier.  They use stock BMW clips to connect to the injectors.
Will they fit?  The answer is no!  Been ther done that.  There isn't room for much of anything sticking above the manifold injector boss.
post-9282-0-25246100-1370473399_thumb.jp
post-9282-0-49127800-1370473450_thumb.jp
post-9282-0-02368200-1370473505_thumb.jp
Injectors are getting shorter, and easier to install and/or hide...
1971 Corvette, BBC to LS1 swap under way
1991 Camaro, ProCharged 355
1969 Corvette Greenwood/IMSA project
1974 BMW 2002, barn find, M42 on a stand, turbo header in a box
