Dent In Gas Tank
Honolulu
My '76 has a large dent in the back portion of the tank.  Any suggestions to pushing it back out appreciated.
I am thinking to remove the sender and poke something in there.... but maybe sealing the empty tank and using compressed air would be a possibility.
Thorts, anyone?
drive car till nearly empty or remove lower drain bolt if your tank has one
and drain contents
disconnect the battery!
support with jack stands!!
remove tank gauge sending unit and with a long clean piece
of 2x2 wood gently use as a drift punch and tap out the dent
from inside.
DO NOT USE COMPRESSED AIR!
your likely to do more damage than good
depending on how it's dented, you may be restricting
fuel pick up, and you may have reduced capacity
Edited by c.d.iesel
