M44 Swap Which Oil Pan And Pump?
DaveBMX
post-32364-0-69717200-1370130378_thumb.jIsn't the M42/44 pump wrapped around the nose of the crank, in a fashion unknown previously (or hence) to BMW?
One that precludes bolts falling off, sprockets coming loose,  chains failing, or other potentially devastating failures.
So I think you just make sure the pans have the same passage arrangement (the pickup is in the pan) and bolt them together.
One note- getting the M42 to prime itself is not trivial- make SURE you get oil pressure before you let the thing fire...
hth
oh God haha so any idea what i do about the pickup? I have the e30 oil pan and pickup and the e36 oil pan and pick up can i make something that works out of the two? can i weld the top half of the e36 pickup to the bottom of the e30? also i need the m42 lower timing cover?! where do i get one of those doubt people will be parting those out :/
The way in which the pickup system works varies drastically between the two engines. I don't see any way around installing the lower (inner) timing cover (which includes the oil pump) from the M42 onto the M44 in order to use the front sump M42 oil pan. It's been a few years since I did it but I don't recall any decent workaround and I'm pretty creative.
Budweiser...It's not just for breakfast anymore.
Avatar photo courtesy K. Kreeger, my2002tii.com ©
No, not if you're going used. The oil pump is part of the cover assembly. The difference is in the way the pickup attaches. The one possible way you might make things work without the cover is with some really creative welding / fabrication. Go ahead and source the used E30 sump and remove the E36/M44 sump. Then you'll see exactly what I'm trying to explain. HTH
Doinking around in Penskeparts, it looks like it all changes in 9/95... oil pan, pickup, etc.
That would coincide with the M44.  And all of the E36 stuff looks rear- sump, where the
2002 needs a front sump...
But thinking back to playing around with E30 M10 pans, THEY don't exactly fit into the
2002, either... but they ARE front sump.
In my neck of the woods, I'd hit the pik- n- pull with my 10mm socket, drill, and an assortment of extensions.
ok guys had the m44 pan off and compared to the m42. take a look
now i tried the m42 pan on and it lines up perfectly and apart from the 42 being a rough cast design and the 44 being cnc'd
this is the engine side
pan as would be fitted
heres the test facility haha
regards
Your engine appears to be an M42, not an M44. If you look at the diagram Toby posted earlier in your thread you can see the type of pickup I have been warning you about, which wraps up and over and bolts to the back of the timing cover, rather than pulling oil up through the port in the bottom of the cover. Maybe it's different than the '96 M44 I set up for a swap. You can bolt the front sump pan right onto that engine.
That DOES look just like the bottom of the M42... but those little rockers scream M44.
(btw, they actually reduce mass, by letting you put the hydraulic lifter in the block, and you also get a roller, not a slider, cam.  Said the cam shop.
Doesn't seem like progress, but apparently, it was.  Who knew?  Not me.)
its a 97 m44 as far asi can tell. maybe its because its a uk model? anyhow im actually really glad as thats one more headache taken care of! i now need to swap out the water pump :/
kind regards
Dave
