Early 1600 Clutch
My early 68 1600 makes some crazy noises when I push the clutch in.
Sounds like its sucking air but in really jacked up kinda way. Does anyone know what clutch differences are in early BMW's ? Do they run off vacuum as well ? <-- I know this sounds really lame (vacuum part), but Im still a newb and learning as I go.
any input is always greatly appreciated.
1968 BMW 1600 Chmnx White
1976 2002 Parts car
2003 f150
60% of the time, it works every time!
The clutch is different from later 02s and can be mechanical or hydraulic actuated. Either way, these cars have a much different pressure plate and throwout bearing. Check the slave cylinder to see if its leaking if hydraulic ( you will have a clutch reservoir near the fuse block). They can be adjusted, mechanical or hydraulic. Could also be the clutch master cylinder.
HBChris
`73 3.0CS Malaga `69 2000 NK Atlantik
'70 2800 Polaris '75 2002A Red
If it is still stock it has a mechanical clutch linkage not hydraulic. The pressure plate will not be a diaphragm style, it will have 3 fingers and 9 coil springs. If it is making noise I'm going to guess it is the throw out bearing and I believe they are the same as the later 2002 TOB.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
..........or the pressure plate is coming apart.
Springs, Levers, Rivets, ... many pieces can come apart
on those early 'mechanical' clutch pressure plates.
. . . . .   and No Vacuum  with any BMW clutch system
'64 R27 250cc #383851 18,000m
ok, this noise makes sense now. The noise sounds like a ford powder steering unit (if you guys are familiar) or in general when the power steering is low on fluid.
it has pressure, clutch feels great, no slippage, also pedal is NOT collapsing. Maybe some fluid and adjusting ? hmm.
anyone now how to adjust ?
1976 2002 Parts car
2003 f150
Im just assuming. I need to take a gander tonight when I get home. If its Hydraulic I should have the fluid reservoir on top by the fuse box right ?
If its mechanical there should be no Hydraulic fluid reservoir right ?
Anyway better way to tell ?
1976 2002 Parts car
2003 f150
My guess ...throw out bearing .If everything else is working ok and it only does it when you push the clutch pedal in, probably a that.
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2007 Lotus 7 Replica
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
The T/O bearing is very different for early cars, it's much wider and hard to find. Coupeking has them. Clutch plate itself is the same as all others. Look for the reservoir.
HBChris
Unless your engine or flywheel have been switched from the original, your '68 1600 has a mechanically activated clutch (not hydraulic), a coil spring pressure plate (not diaphragm) and is 200mm in diameter, not 228 like the roundie 2002s (and all tii's) or 215, like squarelight 02s.
Your clutch linkage is adjustable--the adjuster is on the pushrod that connects the pedal linkage with the throwout bearing withdrawal fork.
A bad release bearing will make noise only when the clutch pedal is depressed.  If in fact the problem is the release bearing, the P/N is 21511204225.  If it makes noise when idling in neutral, it could be a bearing in the tranny or the pilot bearing inside the crankshaft.
Incidentally, 2002s with the coil spring clutch (before VIN 1665200) have a hydraulic clutch linkage, but still have the adjustable pushrod, just like the 1600s.
Mike,
I can almost guarantee that the T/O bearing listed, which superseded the original part, will not work. When I rebuilt my early 02 three years ago I bought that new part. Only the outer 2 or 3mm made contact with the three fingers on the early pressure plate, it looked like a recipe for disaster. The original has been NLA for years. I found one which was repacked with new grease and it worked fine. BMW doesn't always pay strict attention to the little details.
Chris
HBChris
