Clutch Suggestion For Mm Transmission
I recently purchased a Metric Mechanic Tranny from a friend in the DFW area I was also going to go ahead and replace the entire clutch while replacing the Tranny with the MM, does anyone have a suggestion on what type of clutch size I should look into everything in the car is stock expect the carb 32/36 weber
1972 BMW 2002 Charmonix
In order to run a 228mm clutch you need a 228mm flyhweel. Check what you have before you order. Unless you are making a ton of power or racing, stick with a stock clutch for the comfort and ease of use. I have always been extremely satisfied with Sachs... high quality and excellent feel.
1974 Grey European Market BMW 2002
1976 Yellow BMW 2002 "GOLDENROD" SOLD
1972 Yellow Austin Mini 1000
A bunch of Bikes...
I see that bavauto does have the Sachs but a bit pricey almost $450 anyone have a source with a better price?
www.rockauto.com
A bunch of Bikes...
or Blunt...
www.blunttech.com
Naw, the stock 2002 clutch is fine up to 200 hp if you don't let it slip or flat- shift.
Heck, I have a 215 in the street car, I DO flat shift, and it STILL works fine.
BMW knew what they were doing.
