After Sitting For 5 Years
Just picked up a 76 that has been sitting for 5 years.  Of course the PO said "ran before parked", and it obvously was, as it had to be running to rear end a truck and damage the front nose clip to the point where the radiator is unusable. Anyways...tonight I got into the car and with a jumper cable hooked up to the battery tried a few things out.  Motor turns over great, all electrical works great, even the cig lighter. Wipers, flashers, everything seems to be in great working order.  Im trying to put together a list of things to do before I try and start it for real (after front end body work is taken care of)
Empty gas tank
Blow out fuel lines
New fuel filter
New plugs
New radiator (have one from a 69)
New battery
Carb...clean? Rebuild? Or replace. It has the stock carb on it right now.
Can anyone think of anything else Im missing?
Brake fluid, master cylinder , wheel cylinders, calipers, clutch m/c & slave, hoses, fuel lines ( rubber) flex brake hoses , steel brake lines .
are a few more details that will need attention/ checking., as above & add an oil filter into the mix.
1970 4 speed 2002 (Daily driver/track car )
1974  Hybrid powered twin cam engine, Pig Cheeks , ( now a round tail.) Getting ready to Sell
