Weird Blinker Indicating Issue
tim355
I've got a strange issue, maybe someone can help. When I turn my blinkers on, the green blinker indicator light only comes on once. The blinker lights are working fine but I have no indication in the cockpit except for the first time. When I use my flashers the green indicator light blinks normally. Any ideas?
This is probably a pretty easy issue to fix.  If you can find it in the archives, there are a number of posts on how to fix.  It's probably the little set of relay points inside the flasher unit--they get out of adjustment and prevent the inside blinker light from operating.  If you can't find the archive post, send me an e-mail and I'll send you the column I did on how to repair.
cheers
