Exhaust Manifold Question
i searched a bit and as usual i either dont have the skills for searching properly or this shits hidden in here. does a 318ti header fit on the m10? mines a 76 and im desmogging it. if i assume correctly, the 318ti had an m10 in it so it should fit but does it have issues clearing the firewall etc?
thanks,
chris
Not a 318ti...that's an E36 with an M42/M44 twin cam...totally different engine from the M10 in our 02s and of courese a totally different manifold.
What you mean is the exhaust manifold from a 318i--an E30 3 series with an M10.  You're better off just finding a 2002 manifold--there are plenty around, and the one everyone likes is a tii manifold as it doesn't have smog junk--and neither do some of the early 02 manifolds.  Then you know your existing exhaust pipes will link up--a lot less hassle.  Anything will be better than the boat anchor you currently have--it's only fit to throw in CD's neighbor's pool!
cheers
