I think I got this right, but want to check.  I installed the rubber grommet / sleeve / hose in both front blinker buckets.
Here's how I installed them
The short hose in the front hole and the long one in the rear.
The long one is then inserted thru a second hole in the inner fender into the space behind the head lights.
And both wires for the blinker are then routed thru this longer rubber sleeve grommet.
Right?
Byas
