Driveshaft Theory Question
xferboy
Hi,
Just got my driveshaft back from a friend that helped out with centre support bearing replacement. While it was away, I was looking at the parts diagrams and noticed all the parts at the front end of the driveshaft. I could not remember them when I had taken the shaft out last Oct.( could have been there, could have been missing, I just never knew to look)
Parts 1to9. http://realoem.com/bmw/showparts.do?model=2583&mospid=47141&btnr=26_0136&hg=26&fg=10
thankfully they were there.
Now the questions:
1). What do these parts do?
2) Is there any maintenance required for these parts?
Thanks in advance
Allan
It actually IS pretty important- the rubber ring (gooeybow) doesn't guarantee that the shaft stays centered.
The centering ring does, and it provides a defined pivot point for when things deflect.
They can wear out, and they can wear grooves on the trans output shaft, too.
Hi--
With your driveshaft out, pack lightly with good grease; I like Redline.  This bearing can get a little noisy if it gets dry.  You will know that if you think a nest of crickets made a home in your transmission at certain speeds (like 35 MPH).  I suspect the centering bearing restricts excessive movement in the guibo, helping to extend its life.
Larry
