What sadist at Behr designed that a/c console?!
Just finally finished the reinstallation of the Behr a/c console around the evaporator assembly. Holy hand grenade, what a pain in the ass. 40-year-old plastic designed to crack when muscled back into the position the mechanic at the dealership slammed it into in 1972, which must be accomplished with 8mm bolt heads you can't reach unless you have the fingers of ET.
Heater box and evap assembly were rebuilt first. Then leak-tested the system for three days with nitrogen before I was ready to button it up, as I hope it's another 40 years before someone has to go in there again.
Note to all who come after me: The ears for the faceplate go below the dashboard, and the ears for the evap assembly go below that. Try it the other way and it fits but the louvers in the evap assembly won't rotate.
Beer.
1972 tii (Louie), 1973 2002 (Hampton), 1975 ti tribute (Bertha), 1972 Bavaria, 1973 3.0CSi, 1979 Euro 635CSi, 1999 Z3, 1999 M Coupe, 2003 530i sport, 1974 Lotus Europa Twin Cam Special (I know, I know...)
I know what you mean! I got the Behr going again in my car after rebuilding the fan motor, and that doggone faceplate broke at the 2 mounting tabs at the top. You just can't win with automotive plastics!
1974 Malaga 2002 4282899 "Little Red"
1976 Polaris 2002 2374061 "Rusty Shackleford"
1998 Dk. Blue Volvo S70 T5 "Carlene"- 221k Miles
C'mon guys. It's not that bad if the pieces haven't baked outside for years. I've pulled my Behr A/C console twice - both times moved into the pass. footwell without opening the lines. First time to clean the dusty vents, then another time to pull the heater box and install a better faceplate.
It takes a little practice...
Drove my tii in Central Texas for 15 years, 10 of those as a daily, with no AC. Some folks would complain if you hung them with a brand new rope . . . . . .
1973 tii, agave, since 1992
1973 tii block 2763759
1967 Mustang GT fastback, since 1986
1999 Toyota 4Runner, 5 speed, ELocker, Supercharged
I'm not sure you can actually use the modern word 'design'
with things like this-
it's more of a 'Ah, that's close enough, it's time for more beer.
Who needs air conditioning in these little things, anyway?'
sort of affair.
Kind of like Ford bolts that have studs welded to their heads so that
they can be 'double ended' fasteners'
