MegaSquirt and coil packs..
dlmrun2002
Yup. That is the impression I have gotten over the last few years every time I stick a toe in the MegaSquirt Pond. I have the L Jetronic in already so that helps leading into the MegaSquirt swap. It would be awesome to custom tune the efi since the L Jetronic is very limited in a 2.0 block. Still gathering info.
dlm ny country
In this day and age I would just run LS1 style coils rather than EDIS. Easy to set up with either MegaSquirt or a Haltech.
Rob
1971 Corvette, BBC to LS1 swap under way
1991 Camaro, ProCharged 355
1969 Corvette Greenwood/IMSA project
1974 BMW 2002, barn find, M42 on a stand, turbo header in a box
Rob
Do tell! I'm liking this idea on my MS project.
-Nathan
Rob
I agree, I messed with EDIS for a bit but it's an impossible black hole when something goes wrong, no easy way to troubleshoot. Direct ignition through LS1 coils is much more straightforward.
I haven't worked with LS1 coils or any COP setup first hand, but working with edis isn't as bad as you make it out to be. There really is nothing too it; PIP and SAW lines carry info from your ecu to the edis and alter timing. There's two lines for the coil pack and other than the sensor pickup the rest of the necessary wiring is just power and ground. It takes 10 seconds to test an edis coil (check primary and secondary resistance, if out of spec replace) and if that isn't the problem you can always run edis on limp home mode to see if your problem is with the edis or the ecu.
The edis units are fairly bulletproof and running issues are most likely caused by bad grounds, loose connections, and interference if you don't route the wires properly or don't shield them. Really nothing out of the ordinary.
1974 Grey European Market BMW 2002
1976 Yellow BMW 2002 "GOLDENROD" SOLD
1972 Yellow Austin Mini 1000
A bunch of Bikes...
LS coils are "self powered" and do not require an ignition module. Wire them straight to the MS and you are good to go. They can be set up direct fire if you have cam sync or waste spark if crank wheel only. Set up info is all over the MS forums. Mounting brackets and wire sets are easy to buy or fab. With no module, diagnosis is easier, and spares are everywhere.
Awesome! That's what I was reading!! I know what all I'm doing now on my MS build! To the junkyard I go!
-Nathan
