points or no points
rnavarro
Pertronix = when it kraps out - you coast to the side
of a dark wet road with no cell service, no parts,
thumb stuck up butt, no clue as to what to do...
Points = when it stops the motor - you coast to
the side of a well lit dry roadside, remove the
distributor cap, wipe your girl's nail file,
business card, pen knife edge between
the contact points. Close hood and drive on.
'64 R27 250cc #383851 18,000m
Now THAT's funny! C.D. and I are obviously a couple of the more, shall I say, "seasoned" owners here! We''ve both been there done that! :-) Ah, the good times......
...Points = when it stops the motor - you coast to
Mit freundlichen Grüßen
John Weese
'72tii "Hugo"
'73tii "Atlantik"
'74 '02 "Inka"
'76 '02 "Malaga"
'72tii engine VIN 2760081 - waiting on a rebuild
"Keep your revs up and watch your mirrors!"
With the Pertronix installed, I have direct experimental evidence (my eyeball) that, when you're shining the timing light on the ball pressed into the flywheel, the location of the ball is noticeably more stable. Of course, as another poster noted, if your dizzy itself is old and sloppy, it's a moot point.
If you're going to install Pertronix, be absolutely certain you have the resistance of the coil and ballast resistor correctly paired at 3 ohms (many threads on this). If you don't -- if the resistance is too low -- you'll draw too much current and you'll fry the Pertronix in a New York minute. Ask me how I know.
1972 tii (Louie), 1973 2002 (Hampton), 1975 ti tribute (Bertha), 1972 Bavaria, 1973 3.0CSi, 1979 Euro 635CSi, 1999 Z3, 1999 M Coupe, 2003 530i sport, 1974 Lotus Europa Twin Cam Special (I know, I know...)
Use a Capacitive Discharge (CD) system that amplifies the spark like an all-electronic system, but is triggered by points. The advantage besides the hotter spark is the points only carry 12 volts, not the thousands of volts that go to the spark plugs, so they last (almost) forever. I've run the same set of points for well over 100k miles with a CD system--the rubbing block wears out before the points.
And, best of all, if the CD box craps out, you press a switch on it and you're back to conventional ignition--with the points already installed. I've been using Delta Mk10 boxes for years (no longer made but show up on e-bay) but I'm sure there are modern versions.
cheers
Hahaha....
