SOLD!!!!!!!!FS: Los Angeles, Ca: 1968 BMW 1600
Hello,
Up for sale is my 1968 BMW 1600. Please see the very description below.
The BAD:
Salvage title, due to very minor rear end incident
Rust (left frame rail and right rear window and rockers), all fixable, had it looked at by a professional. I have found DIY for all the rust repairs on 2002FAQ
Knuckle head paint job (rattle can paint will come off, I started removing it from the hood)
No front bumper (has rear though)
Needs mirrors (may be able to dig some up)
Rattles a little/Interior is beat
Working tachometer and speedo (speedo just needs cable), needs fuel sender
The GOOD:
Solid front and rear shock towers, no rust in windshield area, and all other areas
2.0LTR motor(strong 155+ PSI compression across the cylinders)
Clean fuel tank (no rust, dents or damage)
Euro turn signals
Smooth shifting 4SPD + E21 transmission mount
All electrical works (turn signals, emergency lights, low/high beams, taillights, windshield wipers)
New guibo/driveshaft bearing
320i radiator +silicone hoses + new thermostat + new water pump +electric fan with temp switch ($400+)
Nice condition headlight grills (used ones go for $500+) (I believe 1968 1600 grills are much rarer than standard 2002)
New gas filler neck (was $100+) and BMW locking gas cap
New brake pads and fresh fluid
Working stereo
Decent rear bumper
Extra left fender included
Doors and trunk lock
The car has great a little engine (smokes only on hard decel). I wouldn't hesitate to drive it anywhere. If I kept it I would probably just put some good tires/shocks/springs and drive the pants off of it.
I have always used 91 octane from Chevron/Shell/Mobil and the valve-train shows it. The valves/ports were incredibly clean when I removed the intake manifold.
I am listing this car as forthcoming as possible.
I can assure you most people aren't as honest in their description.
The car gets nice gas mileage too and compliments too.
Asking $2200 OBO.
Give me a call to schedule a test drive. The car is currently registered and I have the title in hand.
Thanks,
Marco V
323 712 8359
