Exhaust Manifold Nut Tightness?
jjbunn
I had a leak from one of the studs on my exhaust manifold, so bought a set of new studs, lock nuts and gaskets, and fitted them (with red Loctite on the studs).
At first I didn't tighten the locknuts too much, but there seemed to be exhaust gas leaking from all four ports. I tightened them down pretty well, but no real change. The manifold appears to fit very snugly, so I'm baffled.
Now I'm wondering about the gaskets: should I have used some sort of sealant on the gaskets?
The other possibility is that in the meantime my head gasket has sprung a leak, but I prefer not to contemplate that :-)
I'd welcome any advice, thanks!
'73 Malaga 2002 "Cyril" http://bmw2002driver.wordpress.com/
Prior Scruffy Drivers: '69 E-Type 2+2, '74 914, '71 TR6, '73 MGBGT
The nuts typically need to be as tight as you can get them with a combination wrench,
and they also want a re- tightening a couple of times after you do the job.
If it leaked for a while, it may have eaten the gasket, after which no amount
of tight will help- sorry.
No, no sealant, but anti- seize on the studs does make things easier next time.
If you got them pretty tight at first, you might have a warped exhaust manifold-
unusual, but not hard to fix-
just get it cut flat by a machinist.
Might also be a crack- they do crack sometimes, especially with lean mixtures.
Probably not the head.
Don't let it leak any longer than it has to- it can damage both the head
and the manifold.
hth
the face of the exhaust manifold will over decades
and 1,000's of miles of leaking, heat cycles become
very rough and uneven so sealing is not happening.
Remove the manifold and resurface it on a glass
surface with course Emory cloth taped down.
After your first pass you'll see how warped and
nasty that sealing surface is. Keep sanding untill
the sealing surface it true and clean - THEN
reassemble with NEW heat-shield-one-piece
320i gasket.
'64 R27 250cc #383851 18,000m
If you will replace that exhaust gasket, there is one from a later car that incorporates a heat shield to protect the plug wires. It works pretty good.
Copper nuts help too when the removal day comes around.
1972 2000tii Touring #3422489
FAQ member #5
This turned out to be something different: it was the valve cover that wasn't tightened down enough, so oil was seeping through it and burning off on the exhaust headers.
I'd replaced the valve cover gasket, and been overly cautious about tightening the acorn nuts.
In your initial post you said "exhaust gases were leaking". How are exhaust gases leaking from your valve cover?
I put 2 and 2 together and made 5 - I assumed the smoke I was seeing was from the exhaust manifold I'd just refitted, whereas it was in fact from oil burning. The smoke looked like it was appearing from the manifold.
Last set of valve cover acorn nutz I ordered from BMW had built-in flat washers. They were taller, too. What's up with that?
1973 tii, agave, since 1992
1973 tii block 2763759
1967 Mustang GT fastback, since 1986
1999 Toyota 4Runner, 5 speed, ELocker, Supercharged
