Fitting this alternator on my tii- m3 s14
peteinjp
I have this on hand and know for a fact that it is a good unit. The unit in my tii now is a solid mount with a poorly made solid mounted adusting arm and requires a spacer to fit as well. I have had some trouble with the alt bracket loosening and while I think I have it under control I'd just feel better about having a rubber mounted unit in there.
So my favorite option is to switch out the front cover with a stock tii unit cover-
yea or nay?
Barring that I'll make up a spacer and fit this one but I'm wondering if I need to switch out the pulley or not. It is larger than the belt but I see no reason that it would not work anyway.
What is that black thing hanging off the back by a wire in the 2nd pic? Radio suppression or something? Since my current setup has nothing like that I'm thinking (hopefully) that I can ditch it.
And in the 3rd pic what is supposed to attach here under the bolt with the #4 on the head?
Thanks,
Pete
Isn't that an internally regulated alternator? If so, you will have to bypass/remove your stock tii one. Have you examined both front covers to see if they are interchangable? I'd just put a spacer in there. Wonder if the front suspension spacer pipes would work if cut down?
