Had enough of your short shifter yet?? Go Long!
peteinjp
I got tired of my short shifter from auto solutions. No problems with the product in any way. I just hate miss shifts and wanted the shifter closer to the steering wheel as well. While I had the tranny out to swap in my close ratio tranny I found a longer NK shifter and welded on the lower half from the short shifter to keep a bit of a short shift but put the knob up high. I love the result. It doesn't bother me a single bit to have a longer throw and I like being absolutely sure of which gear I'm going into. But most importantly I like having it closer to the wheel.
pete
[/img]
Now that's different! must be comfortable to shift.
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
I'd call this medium shift. The auto solutions was much shorter. This setup has the pivot raises and the lower part of the lever extended. I want to say that the lower part is about 55mm and the upper is about 200 which puts this shifter to about the same as a z3 2.8/3.0 unit- around 4:1. The lower linkage is in line with the selector shaft. Unfortunately I did not take any shots.....
Pete
