FAG Brake Master Cylinder
Inka’d02
So I purchased a tii master cylinder on ebay. I'm upgrading from a stock master due to a Volvo BBK. It was suppose to be an ATE but an FAG showed up in a generic box. The part number on the side of the cylinder is S5339 9A2. Its about .150" bigger in diameter.Can anyone confirm this one is correct before I spend the time installing it?
Thanks,
Andrew
Have you tried the Volvo BBK with the original MC? It should work just fine.
The larger MC will require more pedal force.
Too many cars.
I don't know about your P.N. According to the manual (blue book), the diameter of the regular MC is 20.64 mm (.8125"). The diameter of the TI and tii is 23.81 mm (.937"). The difference is 3.17 mm or .125".
I have the same brake conversion you have and the pedal is firm, with possibly a bit more travel. You might try bleeding the system once more. Good luck.
Too many cars.
I wouldn't rely on that measurement. BMW used several suppliers for the same cyls. The only way to confirm (unless someone can verify your casting numbers) is to measure the bore diameter. If memory serves, you can see the end of the bore if you peel back the rubber bellows on pedal end. Use vernier calipers.
measured where?
The bore diameter, of course.
Too many cars.
Don't sweat it. FAG makes good parts, and I've run Volvo calipers on
all of our cars with the stock master- it's not particularly spongy.
And the bore's the only thing that matters- the OD will vary between manufactures.
In fact, some may make the OD intentionally big to be able to bore different
sized parts out of the same casting. Thus, don't count on casting
numbers to tell you everything, either.
hth
