Trim Clips
NullZwei
Hey there if this is the clips for the belt line trim or well any clips honestly we carry them all give us a call!
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
Not sure who I got mine from but i hope they have been improved since then. My stainless metal t bolts I bought for my car didnt fit correctly and I ended up not using them. This was 5 years ago. I ended up using OE
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
Would these be stainless clips or the standard non-stainless BMW OEM ones?
It's the plated steel ones from BMW sorry no more stainless.
E23 730 1978
won't give you any trouble if you take a few minutes to
(1) test fit the plate, then cut the stud off with a Dremel tool so as not to booger up the threads. The factory used side cutters after the nut was run up causing all sorts of problems when trying to remove that itty bitty nut.
(2) visit your local hardware store and buy some stainless steel nuts in the proper metric size, and
(3) put a little dab of anti-seize compound on the threads before installing the nut.
cheers
And don't forget to put small flat washers under each nut. It gives you one more opportunity to drop things as you assemble, but some of the holes in the sheet metal have enlarged over time and you need the washer to keep the nut functioning as intended.
I spread a good-sized cloth under each area as I work there so when I inevitably drop the washer or the nut, or both, I can find them. Trust me, you don't want to try to find them down on the surface under the car or somewhere in the engine compartment.
Bob Napier
  • 1 year later...
are there better options other than this "kit" from ebay? And is this what I need? And finally, what do the plastic clips hold on? I have a 74'.
The plastic clips hold the upper aluminum trim pieces on. The metal ones are for the ends of the trim strips. The 4 long metal clips are for where the center hood & center trunk trim pieces meet the side trim pieces.
While it's nice to find this in kit form, you might find competitive pricing from Kpeters/Maximillian Importing, or even your local dealer (if they can/will look up the part #s for you!).
John in VA
