32/32 DIDTA carb and adjustng valves when cold
RAS-2002
1. The only way I can get my '72 to idle when cold is to turn the turn the Throttle Valve Adjusting Screw (screw #10 in c.d.iesel's diagram). And yes, this is the screw, which on the diagram is underlined in red, stating explicitly: "Do Not Adjust". So, when I adjusted it, how bad of a Bad Thing did I do by adjusting it?
2. I've seen many times: "adjust valves when engine is cold". The temp in my garage is 40 degrees. When they say 'cold' is there a temperature that's recommended? Is 40 degrees too cold? Should I run the engine for a minute or two? Or not?
Thanks,
Bob
-Bob
(current: 1972 Malaga 2002, VIN 2584644, build date July 26, 1972)
Previous: 1973 Sahara 2002 #2585896 (RIP), 1969 1600, 1971 2002, 1964 Triumph Herald convertible, 1965 Triumph Herald convertible, 1961 Triumph TR3A, 1967 Triumph TR4A-irs, 1959 Austin Healey 100/6, and about 10 other cars (most of which were quite boring)...
1. bad? you.ll Spontaneously Combust
2. that.s plenty cold enough for the valve.s
but you might need mitten.s for your hand.s
'64 R27 250cc #383851 18,000m
The temp for the valves in the car is fine, but, as c.d. points out, it might be a little cold on your hands. You say you're in a garage so maybe slide a chair up along side you with a portable heater pointed at your rear end. That should be enought to get through what is usually a pretty short procedure.
Bob Napier
Human spontaneous combustion: I knew there was a price to pay for turnin that danged screw! Mein Gott! I burn in hell forever now!
As for the valves, I'll put ze mittens on and have my wife point her hair dryer at my frozen butt while I adjust zem...
Thanks!
Bob
-Bob
