Where can I find a TII wiring harness??
Needing some advise on where to locate a 1972 TII wiring harness. It's a long story but I'm putting a rebuilt 1972 TII motor into my standard 2002. I need a way to wire in the cold start sensor for the fuel pump and such.
I'm at a loss about where to buy a TII wiring harness as it isn't something readily sold used. Does anyone sell them at a reasonable price?
Any help is much appreciated.
The cold start harness may still be available from BMW - it does not come with the rubber boot at the solenoid valve. Look at the fuel injection throttle body parts section for the harness.
You can simply make a long harness for the fuel pump. There is a connector under the dash.
Mike Wooldridge of Arkansas just did this conversion to his car.
New cold start harness from BMW. Per Penske Parts website, both are NLA! Top one since March 2010 and the bottom one since September 1990.
13 61121354671 WIRING SET (01/70 to 10/75) 0.26 1 NA
13 61121358281 WIRING SET (09/73 to 12/74) 0.44 1 NA
directly above the hood release handle and above the wash/wipe and turn signal relays. You should see an unused female terminal with a plastic sleeve around it.
With a voltmeter, test and see if it's hot only with the ignition on. Then, with the ign on and the voltmeter connected, pull fuse 11. If the voltmeter drops to 0 then you have the correct wire. On tii's it's what powers the electric fuel pump, so all you need to do is run a wire from there back to wherever you mount your fuel pump.
For the cold start harness, if you can find a useable plug, you can make your own harness and solder the wires in place to the plug.
cheers
