oversized Eccentircs question
nbristow01
I have a head I just had redone with an new valves guides seals seats etc etc. I have an IE regrind 292 in the head. I have a set of oversized eccentrics to install but wonder if they are really needed. I have no problem adjusting the valves to .006 or .007. with the stock eccentrics I had the machine shop put in. I believe I read a post and Toby said he runs regrinds and has never had to use oversized eccentrics.
So question is, do I need them if I can adjust the valves with the standard eccentrics?
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
You do not need them if you can use the standard eccentrics. So in your case, nope, not needed.
They are needed sometimes if the base circle had to have enough material removed (or if the valve seat is moved). On a 292 they are generally not needed, but then again I have come across some who need them. Go any more extreme on a regrind and there's a always a pretty decent chance.
If I did, I was lying out my a**.
Every reground cam I've ever used
has needed either larger eccentrics or lash caps.
With maybe the exception of the Ireland 'new billet' grinds-
I forget what those needed.
Sorry if I misled you down the golden path of rocker distortion...
The issue is valve timing. While you can achieve the correct lash gap. Becuse the cam is ground below the billet base circumference, it changes the angle at which the rocker will move the valve, acentuating a valve timing distortion. Seemingly creating an ignition timing issue. Chased myself around a corner with a 300 regrind for exactly this reason.
Daron
Daron
But you can't correct the rocker angle by any of these means. Only way is to use a fresh cam (=not re-ground).
-> If you're able to adjust the gap to correct value you don't need to change anything. If not, bigger eccentrics or lash caps will give the same result.
Tommy
Toby, you are correct. I misunderstood, you said you have used regrinds with no issues, the eccentric part must have come to me in a dream because you did not bring that up LOL
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
Oh, but I DO lie like a rug sometimes, so it's entirely possible I said that once. Or more.
But it wouldn't be true.
heh
As to a valve timing issue with a regrind, in THEORY,when making the cam, the grinder adjusts
for the change in lash pad position and rocker geometry. In fact, they HAVE to, at least to some
degree, to keep the lobe on the pad.
Whether that's done properly- or at all- is another issue altogether.
The L-series Nissan guys take a LOT of time to make sure the lobes
stay on their rockers, but we don't seem to have the problem to the same
degree...
  • 7 months later...
