e30 steelie users..question
eurotrash
Yes, larger overlap required. I got a set from Blunt.
I always do it right the second time.
1970 2002 Chamonix (Fiona)
1976 2002 Chamonix (Blanche), '73 2002 Colorado (Nemo), '72 2002 Riviera, '74 2002 Atlantik, '71 1600 Sahara (Binkley) all sold
BMW steel rim VS alloy rim require different
taper 'd nut/bolt or you'll LOOSE YER WHEELS!!
yer on your own if you have after-market - non-bmw rims
no telling what shape your hole is or
nutts it requires
HOLES ARE DIFFERENT
'64 R27 250cc #383851 18,000m
What kind of center caps are those on the steelies? I've got a set of steels in need of those caps!
They are the E30 center caps. I also got these from Blunt. They're quite inexpensive.
While we are on the subject (sorry to thread-jack),
What lug nuts should I use for my aluminum enkeis? Different from the ones I use with my steelies I presume? If anybody has some please email me (or a link to a source).
1966 2000ti Chamonix - old racer, new project
1967 1600 Bristol - stock as a rock
1976 2002 Pastellblau - Alpina tribute
Parts For Sale - The Paddock
taper 'd nut/bolt...
CD do you have the part numbers for the wheel bolts shown - both for steel and alloy?
RealOEM is not showing the numbers for the wheel bolts.
Thanks Beaner7102
BMW didn't have chrome wheel lugs showing available.. Well, at least RealOEM didn't. Black only. So I bought some from tire discounters. they showed them 'correct'.. at least for the steel wheel. Haven't tried mounting one yet, to see if they hold the center cap. But I pressed them in place with my fingertips, as it sits in the picture, and it was secure.
P.S. These are going on the e30.
(O=o00o=O)
Is that a deep blue metallic finish? Looks really cool. Post some pics with the wheels on the car.
