distributor...
esty
steve got the o2 truck running....for a few minutes before it started sounding terminal...it looks like a couple of springs and other stuff down in the dist, under the metal cover, inside the dizzy have broken or come off of whatever they attach to
under the plates (?), i can see the end of a spring on one side and a metal rod sticking out and floppy on the other
anyway...not knowing diddly about it, do we need a distributor...if so, who has one for sale
Yours can likely easily be put back together. Sometimes that spring clip holding the shaft together can pop off and things fly apart. Or a spring might liberate itself.
Looks bizzactly like this:
http://www.sl113.org/wiki/Electrical/Distributor
GL,
Ray
Ask me about my E10 320i's!
'73 320i /M2 2.5; '85 ///M635CSi ; '73 320i ugly car; '99 AMG C43
I'll second that offer. I have 12 spares in my basement. Surely one of them would serve the purpose. Located in Maryland. Might help if you can provide the model number of your current dizzy so I can check whether I have an exact replacement. Less variables, more certainty.
Grice
To answer, yep they're rather simple to disassemble. The hardest part is that little spring clip on the top of the shaft. Get half a dozen of Grice's and practice. You can add a sideline to the carpet biz after!
It's been eons since I pulled one apart tho, so I may be forgetting something. But the top section is all you'd need to disassemble and I do remember it's really pretty simple.
Ray
When refitting the spring clip that holds the top sleeve in place, i used a plastic pen with the ink stick removed, placed it over on top of the spring clip and popped it down in place.
