Timing chain noise, replace tensioner as precaution?
Beck180
Thanks for your response re the oil pump chain, However I  still have some questions.
1. My 1974 2002 has about 80,000 miles on it per odometer.  I am doing the timing cover gaskets due to oil leak. Would it be a good idea to replace chain and guides and tensioner at this time, just so I know it is done ?
 Chain is pretty tight and will not easily come off the cogs, any suggestions?  Can I remove the posts holding the guide in place without the chain being removed? Do I have to remove the camshaft cog to get the chain off? Or should I just drill out a link on the old chain and replace it?
Many thanks.
I think the answer is that you don't need to replace the chain if it is a lot of work. It's not like a cam belt that is good to replace if it's history is unknown. While they can be inherently noisey there is nothing intrinsically weak about them.
That said, if you have the front cover off and you are deadset on replacing it then now is the time. Removing the sprocket from the camshaft is the way to replace it. Though if you are really anal about it you then need to look at wear on the cam and crank sprockets as replacing the chain is only part of the job. These are pretty long lived too but you start to wonder about the benefit of replacing the chain and tensioner in isolation.
rtheriaque wrote:
