Which Redline air cleaner? Two heights for the Weber 32/36
chrisp
height that they used...
Here's a link:
http://www.carburetion.com/Weber/weberpartsair.asp
I'd like to get the taller of the 2 for obvious reasons but just wanted to see if anyone had trouble with hood clearance with the taller version.
P.S. I realize that using the cold air intake line would be ideal but I need to get this car back on the road and the open element air cleaner would do that quick and easy. Then I can work on building a cold air intake setup. My stock air cleaner was all hacked up already when I got it and after trying a couple days to make it work with the new Weber 32/36, no dice.
1974 2002 - Automatic
the tall one. have 32/36 on twm manifold and tall one works perfectly. test fitted by molding a ball of clay, laying on top of the air cleaner cover and closing hood. clay compressed to about 1/2 inch enough for clearance and motor movement under access/decel. one thing that may be a problem is some of the two bbl manifolds had a higher baseplate mounting surface than others so make sure to take that into account. if you have one of those then the 1 7/8 works.
Gale H
Gale H.
71 2002 daily driver
70 2002 malaga (pc)
83 320i (pc)
