Removing steering box from steering shaft
Stevenc22
You really have to pull either the box or the column-
(I'm guessing you already have the box loose?)
and you also have to take the pinch bolts all the way out, and
even then sometimes whop on it a bit. I use a screwdriver to spread
the clamps, and then a copper- faced hammer where needed.
It seems to be a universal feature of BMW steering shafts-
they REALLY don't ever want to come loose.
There should be a braided strap or a "spring" that connects the one side of the coupling to the other side. It provides continuity of ground for your horn.
Remember to "pre-load" the steering column when you reinstall.
1972 2000tii Touring #3422489
FAQ member #5
Hi Steve, I was wondering the reason you are working on you steering box. May be I missed prior messages but I don't see where you state the problem.
I'm having a 'gap' on mine when turning left, plus a 'play' on the steering wheel of about 3". I was looking here for advice on how to deal with it. I wonder if there is any adjustments you can make before looking into replacing box.
Any advice would be greatly appreciated. I have had the car for 3 months.
Dan..
