Camshaft identification "R1"
Juel72
I have found a camshaft with the following markings in the timing gear end.
BMW R1 D
Is there anyone who can assist me in finding out what it is.
Stock/ fast road or ?
B/R
Juel
1975 BMW 2002 Twin Weber
2000 VW Passat TDI
1999 Nissan Micra (wife's shopping cart)
Great.......
Just what I need.
I looked i bit closer. On the edge, next to the timing mark.
There is a stamped mark that could look like a "2"
That means stock....right?
I will take meassurements later today.
B/R
Juel
2000 VW Passat TDI
I have just measured the lobe lift on the mysterious camshaft.
The lift measures 7,2mm.
According to the Schrick catalogue it is similar to their 284 cam.
I think I will try it together with my twin 40mm DCOE carbs.
Please comment if any you have other suggestions or ideas.
Best regards
Juel
2000 VW Passat TDI
That's not bad at all- that's over 10mm at the valve.
If you look at the base circle (the 'back' of the lobe)
is it slightly raised above the casting material, or slightly below?
Below would suggest a regrind, whereas above would mean it's
an 'original' grind on a new blank.
Cool. In all the junk I've ever accumulated, none of it had a
'more than stock' cam. Lots of 'less than stock', though...
heh
Yes, i believe that it is a regrind.
Now I need to find some oversize excentrics for adjusting the valve clearance.
What about valve to piston clearance. Is there room for the valves when using a cam with 7,2mm lift.
Thank you for a great forum.
Best regards
Juel
In Denmark
2000 VW Passat TDI
