Getrag 245 Transmission,shift plaf.,weber 40 dcoe, tii head
Getrag 245 5 speed transmission out of a 1983 320i with 165,xxx miles. Has been checked out and is smooth through the gears. $350 without seals and $375 with seals.
I have a shifter platform for the transmission for use in a 5 speed swap. Comes with a wooden shift knob, could use refinishing. Made to specs.
$125
I have for sale a pair of dual weber 40 dcoe with a manual choke cable. They come with cannon manifolds and have been cleaned. In need of a rebuild. They function smoothly. Comes with manual choke and all linkage. as well as k&n filters - cold start choke
Made in italy $650 or trade
1974 tii head, head has been checked for flatness and is not warped. Never been milled, valves look good and rocker arms look good. Should be checked for vacuum on the valve seats for leakage.- $450 OBO
Intake complete with fuel lines, throttle body, injectors, runners
Injectors move freely but unsure of spray pattern- $650 OBO
I have a pair of black vitaloni mirrors. Come with mounting hardware and gaskets. $60
Set 2 of mirrors- driver and passenger side- gasket and mounting hardware included as well. $100
A 320is sport wheel with hub fitting a 2002,wear on top- $70 OBO
Bosch square halogen fog lamps, no cracks in glass. $75 OBO
Email me at equihuiz @ live dot com or call at 2O9-83O-6215
the carbs look like alfa carbs. did you re-jet/venturi them for the bimmer? how long since they ran? where are you shipping from?
thanks,
don
The carbs came off of a 1976 2002 with a 300 regrind cam e12 head. the head was milled .011 . i am unsure when they last ran. but they are mechanically sound. shipping from 95377
