what tool for unbolting driveplate from torque convertor?
Jace
Though I've never messed with an automatic 2002, these "zero offset" wrenches are the bee's knees for all other BMW torque converter bolts. I got mine from Snap-On and they were expensive...but they are absolutely luxurious and a joy to use.
Paul Wegweiser
Owner: Zenwrench
Classic BMW Specialist
...no special tool - and oil pan stays on the motor -
but you do need to remove the lower sheet metal shield
between the motor and trans so you can easily
see the 4-bolts - just a regular socket and ratchet
are needed. Give the handle a sharp wrap to loosen.
What you may find stopping you is when the torque
converter rusts solid onto the flex plate. you need to
work at breaking the torque converter free so it
stays in the trans while you pull the trans back and off
'64 R27 250cc #383851 18,000m
