Snail Wippers
dansacto13
Hi everyone, my 74'is slowly coming to life. It's finally running after that éngine fire'. Thanks to everyone who helped my with advise and/or parts.
Now I have to concentrate on the 'little' things. One is my wipers. They move at the speed of a snail. Is this a 'rely''issue, or a 'voltage issue, or ís it the motor.?
My 'horn' also is very weak. What do you guys think?
Cheers,
Dansacto..
time to:
clean all fuse box connections - replace all fuses
clean all electrical wire connections
at wiper motor, horns, wiper switch connections
run jumper wire to horn and adjust for loudest
tone with adjusting screw
clean and lubricate wipper moving parts & pivots
dive into wiper motor for cleaning and lubing - last
'64 R27 250cc #383851 18,000m
Snail whipping is a crime in Oregon!
What CD said, but I would start by lubing the pivots for the wipers themselves, where the arms attach.
It's insideously hard to do, as the assembly is designed to keep water-
and thus, oil- out at all costs.
I agree with CD. I greased my wipers because they were super slow and it made a HUGE difference. Also, I hadn't realized there is a "speed" switch for the wipers (I have a '71 and it's not intuitive) but when I found that out it helped also.
As for the horn... I think my snails finally died and it now does not work. Escargot I guess...
Yes, there WAS skin on my knuckles before I started the repair...
Wipers also working better now. W40 all points. Tomorrow I will actually 'grease' them for a more lasting fix. They are not super fast but just enough to get me though a rainy day. I recommend this to everyone, even if they seem to be working fine.
I haven had time to check and lube electrical connections yet, as recommended before (thank you), but I'll post results once done.
Cheers,
Dan..
Rainex - Ilived in Miami for years - It would rain so hard you couldnt see the other side of the street.No wiper could keep up. While people would pull over on 95 I would be blasting by wipers off - Rainex on. Like I was looking thru a clear set of goggles. Oh- you have to re- apply. lifes a bitch.
When wipers arent getting it get some rainex.
Catman
I did the things yesterday no one wanted to -
So I could do the things today no one else can afford.
