IE tii dizzy install on 76 non-tii
jtmila02
Guys need some help on this. I've been compiling all of the relevant threads on this and I'm still stumped on a seemingly rather simple issue. The bosch dizzy that was removed had a single male connector on the black wire. Problem is the new IE dizzy has both a black wire and a yellow wire each with female ends. (see pic)
1) Where does the yellow wire connect
2) I assume I need to switch the female connections over to male tabs, correct?
Any tips or hints are most appreciated.
Thanks,
Jeremy
I have a mechanical advance distributor with the IE electronic ignition on my '76. There is a red and a black wire; red goes to positive on the coil, black to negative (female connectors).
I always do it right the second time.
1970 2002 Chamonix (Fiona)
1976 2002 Chamonix (Blanche), '73 2002 Colorado (Nemo), '72 2002 Riviera, '74 2002 Atlantik, '71 1600 Sahara (Binkley) all sold
Stu,
Thanks for the quick response. The wiring from the positive coil did not appear to link directly to the old bosch unit. Rather, as you can see from the images below (blue wiring bundle leading from positive coil)it looks like it is running to the solenoid valve.
I was hopeful I could get this thing running properly on my own but with limited skill and zero experience working on 02s I may be ready to throw in the towel and have an expert take a turn. At the end of the day that may be the best option to at least start from.
I had an expert install mine. FYI, if you've removed the smog control stuff, the bundle of wires and the solenoids on the firewall can all be removed, and replaced with a single wire from the fusebox to the positive side of the coil (see the extra black wire attached to my positive). Here's one link of many on this topic:
http://www.bmw2002faq.com/component/option,com_forum/Itemid,0/page,viewtopic/t,381290/sid,51c2fc853c955977e66ef8e077f0f105/
