Air in clutch hydraulic line
radio9phs
I have swapped my automatic transmission for a 5 speed 245. I have been having trouble eliminating air from the clutch lines. I have pressure bled from above several times. I can pump the pedal a few times, and see gas bubbles coming up from the line from the master and emptying into the fluid reservoir.
I tried to economize a bit with used master and slave cylinders with refurbish kits for gaskets. (Likely "false economy").
Ideas for gas source? Should I just get new master and slave?
