Waterless Coolant
jmhonnold
Hi:
I am new to the forum, even though I have had an '02 for some time. I have a 1972 2002tii. I am doing quite a bit of cleanup in the fuel and cooling system. It was running a little warm, so I thought a good flush would be a good idea. Actually, I can't remember the last time it was done. I was doing some research online and found a product that I wasn't familiar with, waterless coolant. It sounds pretty slick, no water, no need for overflow, never needs replacing, won't corrode the engine, etc. Has anyone ever used this type of product in their '02? Evans was the name of the company that is selling the stuff I saw, but I am guessing there may be others. Thanks for the help.
John
Evans NPG+ is commonly run (by some - not me) in the newer BMWs with plastic cooling system components and higher pressures.
I've never had a problem running Prestone, Peak, or BMW coolants with distilled water in my 2002s in the past 33 years.
Should you have an emergency cooling system problem and are running NPG+, what do you plan to do?
John in VA
