timing car with getrag245
caskren
?????? you time it as per normal tranny makes no difference.The flywheel (where the timing marks are located ) is connected to the engine crankshaft, not to the transmission.
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2007 Lotus 7 Replica
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
I don't think it matters where the window is - if you see the ball when the light flashes, your timing is right (given that you are doing the procedure correctly). Only if you couldn't see the ball would you have to worry that the window was in the wrong place. I bet the ball will appear as always, regardless of the tranny.
Ah, seems to me if the window WERE in a different location, it would make a difference to timing - in the same way moving the peg at the front would change things. I don't have answer as to whether holes are different from 4 speed to 5 speed O/D (but I doubt it). On C/R box, they are the same.
NOT correct. the ball must be in a specific place in the window.
3xM3
yes i was asking if the window is the same because if it were in a different place it would not work. Just wanted to make sure before i went out there with the light and couldnt find the ball and start to pull my hair out.
thanks for the answers guys
