WTB tii tension spring
Not just any spring will work in that location. Let us know how it works out for you.
Make sure this pin on the underside of the "tuna fish can" lid is positioned to keep the eccentric cam from rising upward.
Just so you know, the spring in your photo is installed upside down. Hence the rub marks on the cam.
I believe those marks were made from the old spring. I installed the new spring so that it does not rub (or at least makes minimal contact). Installing the cover with the pin in the wrong location will allow the cam to push upward and possibly...contact the spring.
My car runs much better with the new spring. I have another spare throttle body that may need a spring. Will keep in touch with you if you have additional ones available.
