Suspension question. Pads?
BMW1974
WElll, on top of the rear springs is a rubber pad, 1 dot is a small one(in height)2 dots thicker , 3 dots thicker still. Differance in height between 1 dot and three, 3/4 " or there abouts , someone will correct me if Im wrong.
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2007 Lotus 7 Replica
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
you need the pad for isolating the metal spring
from the metal body - and the thickness determines
the rear ride height - depending on the springs installed
clean the crusty under coating off so
you see the Dots on the side of the rubber spacer
3-Dot = thick
2-Dot = medium thick
1-Dot = thin
the front uses very thin rubber
at the bottom of the spring and top.
USA cars had a thick (19mm)aluminum spacer at the very
top of the strut to raise the front ride height to
meet USA crash - bumper height requirements.
Standard procedure is to remove that alum spacer
to lower the front for better Roll Center - BETTER HANDLING
'64 R27 250cc #383851 18,000m
  • 5 years later...
