Windshield Locking Bead
Stevenc22
I have the windshield installed with a new BMW gasket. I have the AEGIS tool. But when i try and install the bead, the gasket gets pinched and rips little pieces off. I tried lubing with soapy water to minimize pinching but that didnt help much. Something about my technique is wrong because i am damaging this gasket.
Thoughts?
Thanks
Steven
can you post a photo of the working end of your tool ?
it may need modifing if it sharp edged
here are the nice rounded, with roller special BMW / SAAB
tool which spreads, opens, presses down with roller tool
using a NEW rubber seal ?
'64 R27 250cc #383851 18,000m
not to hijack your thread, but the 76 I just bought does not have a chrome locking bead on the front windshield......I assume that mine is wrong? Wasn't sure if all years had the bead?
'76 2002 A "camo blue"
'73 2002 A Chamonix
'71 Airstream Globetrotter
'72 2002 A Verona-crashed then stolen
2007 Toyota FJ
They all should have the lockingstrip.
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
Lots of guys substitute the black Turbo lockstrip. Perhaps thats what you have?? But as stated you need a lockstrip of some sort
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
Steven - the above tool looks the Mutts Nutts (good)
should'nt be tearing anything - need to press down hard
so the wire loop is under the seal lips - spreading and the
roller presses the lock trim down into the groove - hold the handle
at a low angle nearly level with the rubber as you go - spreading,
pressing, slowly . lub'd up with window cleaner
I'm sure Bill Williams or someone else here has
an excellent photo gallery of the technique - wait
and someone will provide that link
Tip No. 3.
place the new lock trim strip in a pail of "HOT!"
water to soften it before installing - it will flow into
the rubber groove like butta!
  • 1 month later...
Does any one know if these tools are sold in any retail locations?
I went to purchase one online and shipping to Canada was more than the tool. O_o I don't have mail delivery where I'm staying (house rental)
I happen to be in Florida right now on vacation, so if any one knows where one can be picked up, that would be great to know
thanks
Allan
This is exactly why I install the gasket AND the lockstrip to the glass,
THEN put the glass into the car.
I also had trouble not damaging the gasket. The Lisle tool pictured above
really benefitted from a bit of rounding of the stamped edges. Yours
seems like it should be better in that regard.
FWIW,
I just struggled with that a couple of weeks ago using the same tool. I removed the roller as it did not help.
Find the smallest loop thru which it the lockstrip fits easily (was the second smallest I think).
Here's the orientation I used.
As you can see from the pic the rubber could get trapped between the bottom of the lock strip and the tool. So you need to apply lubricant to the bottom of the lock strip as well as the top and groove of the rubber. The mix I used was not strong enough. Next time I'd try a stronger dose of soap in the mix. I wonder it it's ok to used petroleum jelly or will that damage the rubber?
Byas
  • 5 months later...
Bill Williams, by chance can you replace the links to the photos you previously posted? Judging by your past thoroughness, these will be the key to a successful project.  :) I have the tool sent from BavAuto and the locks trips. Now I just need courage.
2012 VW Touareg TDI
2007 Porsche Cayman S
2005 Audi S4
1996 Porsche Carrera 4S
1973 BMW 2002tii
http://www.fototime.com/inv/11E82910DA8C213
An auto glass shop with a tech >40 years old can install the lock strip in ~10 minutes at a minimal cost, unless you truly want to tackle the job yourself! Pros usually use a stiff white plastic tool with blunted ends to open the rubber gasket and get the strip in place without gouging the "chrome" finish.
John in VA
There is a video elsewhere on this forum of some folks replacing a windshield and lock strip during Vintage at the Vineyard a few years ago. It is under Articles or Articles under construction. When you find it go to the last post where somebody reposted the broken links from earlier. I watched them just yesterday and they are really helpful. I am on an iPhone or else I'd find the link for you. Maybe someone else will post it.
'71 02 - parts car with not many parts left
'73 02 - weekend toy and money pit
'74 04 - sold in '91
'03 325iT - for trips and bad weather
'03 50cc Honda Scooter - for my 2 mile commute
'06 50cc Honda scooter - wife's commuter
I found the link. Like I said, go to the last post to see the 3 part video.
http://www.bmw2002faq.com/topic/51780-windshield-install-made-easy/#entry937329
