engine install with or without tranny; that is the question
billpatterson
  • Replies 32
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Any which old way works.
Given how sometimes the engine doesn't want to stab the trans at >>frikkin<<
all, in your situation I'd mate the two, then install. It's fiendishly hard to
get angles right sometimes- and pathetically easy, others.
And I can't really figure out why the difference, often...
But if you decide to install separately, mate them first, and depress the clutch
once or twice.
Then pop 'em apart, and when you go to align them, it'll go just a bit easier.
And even
the scary $40 HF leveller is well worth it, IF you're doing them separately.
Honestly, whatever you're most comfortable with, like CD said.
I took the trans out the bottom and dropped in the engine from the top, then put the transmission in from the bottom. Tried to drop them in as a complete unit into the car and had trouble- it's an automatic shell with a 4 speed manual, but the AC was the cause of my trouble.
This is how I did mine , every thing on the sub frame, rolled under the car, lower car on jacks, life sub frame up to the body, install 4 bolts :)
Harry
Harry: What is holding up the car on the 2nd photo? I can see a floorjack towards the rear with something like a 4x4 going across. Is that it? Seems like a lot of leverage with most of the car hanging forward of the jacking point. Did the body feel stable?
Luis
Harry
It looks like there is a come-a-long or hoist attached to a ceiling beam lifting the front of the car.
The Mobile Tradition Inka tii during the "glass workshop" build
I'm assuming that picture was taken for promotional purposes. The front dolly would require removal to install the engine.
Note the two heater hoses are installed on the engine.
The engine also seems to be attached to a section of the subframe (see steering sector) and the whole thing balanced on a floor jack.
could you lift the front end of a big bumper car with beams in the bumper shock holes? Assuming it would be light as the subframe and engine falls below.
Basically you would support the subframe and engine and lift the car up over it.
FOR SALE-----74 2002tii 2782194 Turkis, Megasquirt, Korman road sport springs, Bilstein HD shocks, 13" FPS Bottle Caps
Hi Luis, The rear sub frame is in the car and it is sitting on the rear tires, the car is held up buy a 3000lb come along which is attached to a very large support beam in my garage, there is a correct size chain, for the weight ,attached on each end buy the large bolt in the engine compartment that holds the bumper on in the later cars. The come along is attached to this chain and easily lifts the front of the body up, roll the complete sub frame under the car and then lower the front on to the jack stands, connect the chain to the motor lift points and lift the motor and subframe off the dolly and up to the bolting location on the body , roll the dolly out and use a floor jack under the subframe for safety, install the 4 subframe bolts and connect the struts and a front axles and connect the tie rod ends then tires, remove the come along raise the front with the floor jack and remove the stands and lower the car on the tires DONE.
Harry
1975 BMW 2002 Taiga
2000 BMW M Roadster evergreen
