Front Wheel Studs (screw-in or press in)
xferboy
OK,
I was under the impression that the front wheel studs on 2002tii's (2763495 coming up on her 40th birthday on Feb 20th) are screw-ins and press in's on the back.
After twisting off stud on the front, I tried screwing it out with little luck. A smack with a hammer to loosen it up only pushed it in a little. Time to pull it all apart.
Yup, press ins. Is this normal? It didn't look like it was threaded and someone forced a press-in stud in.
Is this the right hub, or id the hub get swapped out at one point in the past?
THanks in advance
Allan
