Seat section interchangeable?
the center section that splits, you can either take a passenger seat bottom apart and use only the center section, or cut up an old back seat back--esp one that's rotted at the top) and use it to repair you worn/split driver's seat bottom.
I've had that successfully done by an upholstery shop several times. All the vinyl had aged simultaneously so it all matched--couldn't find the repair.
