electric fuel pump at the tank
montobo
The question is, how well can it work to use an electric fuel pump at the tank (from a 318i, or something) for a down-draft carb set-up? The fuel lines are swapped (steel line to the engine and plastic for return). The car is a '74 carbureted and somewhat disassembled under the hood. It's not my car although it used to be. I had worked on it a little bit and there were still gas leak issues with dual weber carbs. I had used a Carter fuel pressure regulator set at 5 psi. I'm trying to help the current owner, long-distance (I have not seen the car in several years). He is in the process of assembling a fuel hookup/carburetor install from parts. He does not have prior experience in particular with BMW 2002.
Are we on the right track? Does this sound doable and desirable--especially the electric fuel pump? Or is it recommended that we revert back to original? If so, what exact steps are recommended?
I hope I am making sense. Your patience is appreciated.
Thanks.
Unless there is a pressure regulator with return flow to the tank, the pressure will be quite high. If no return flow the pump will probably burn out, it is a positive displacement pump that should not be dead headed.
You are asking about a pump "at the tank". Do you mean "in the tank"?
Too many cars.
