Sign in to follow this
williamggruff
Another parts bonanza from Maryland
9 posts / 1264 viewsLast Reply
It appears that I'm one of several FAQers reducing inventory. While I realize people like to have prices posted, the parts listed here are those for which I have no great attachment, and I'm willing to let them go for any reasonable offer to my fellow FAQers.
All parts are in Maryland, zip code 20735. PayPal preferred, but willing to accept checks and cash.
As always, if you're not satisfied, I'll issue you a full refund. 2002s should be a fun hobby, not a [email protected] hassle.
3 camshaft sprockets:
Sprocket #1:
Sprocket #2:
Sprocket #3:
3 A/C clutches
Clutch #1:
Clutch #2 (needs bearing):
Clutch #3 (needs bearing):
Non-A/C crank pulley:
5 water pump pulleys:
Note that the top pulley (Pulley #1) has a smaller diameter.
Pulley #1 (smaller diameter pulley):
Pulley #2:
Pulley #3:
Pulley #4:
Pulley#5:
Non-tii strut housings
All mounting surfaces, bearing surfaces and threads in good shape, including the three pitman arm holes at the base of the strut housing.
Pair #1:
Pair #2:
Peanut intake manifold
6 non-tii valve covers
Also have 3 silver caps. The first 3 covers to go will include a cap. The black cover has a matching cap.
Cover #1:
Cover #2:
Cover #3:
Cover #4:
Cover #5:
Cover #6:
Caps:
Behr center console parts:
Center console side A:
Center console side B:
Center console side C:
Center console side D:
2 Glove boxes
Glove box A:
(Black streaks are from cleaning with a damp cloth. Glove box interior is charcoal grey, with no streaks.)
Glove Box B:
Spare glove box cushion:
How much for the black valve cover and the better condition glove box cushion? Thanks.
Please note that the two spare glove box cushions aren't interchangeable. The newer looking cushion is from a later model glove box. The older looking one is from an early glove box. If you look at the side of your glove box and it looks angular like this, you want the newer looking cushion.
If the mating surface of your glove box is curvy, you're better off with the other pad, which will look fine with a wee bit of vinyl mending goo on the thin crack in the seam.
How about $40 shipped for the pair?
