Battery Relocation
I just tossed the battery in the trunk. Do i need some sort of ground in the front or can i just run the Neg. terminal in the trunk to the chasis? Im slightly lost, I have the e30 distribution block, Now I just have to run the cable that was on the +terminal before to it right (the big clamp with the red wire coming off it)?
Thanks in Advance
Zack
72 Faded Red (with a new 320 Radiator!)
here is a pic of my rear mounted battery grounded to chassis. This is not the best way to do it, but it is the way the PO did it. following is a pic of a better way to ground in back. Make sure your engine is grounded to the chassis too, and that you retain all the grounds in the engine bay.
